Interproject link disappears upon Activity code change
8 replies [Last post]
Evgeny Z.
User offline. Last seen 1 year 18 weeks ago. Offline
Dear all,
another question regarding portfolios. I noticed, that if I change the code of activity to which there was an inter project link, then this link will simply disappear from the portfolio without any warning upon the next portfolio consolidation.
I understand the reason, where is is coming from, but since activity code change seems not to be something prohibited in Spider, this looks to be quite a risky situation to lose the interproject links.
Is this an expected behavior?
Regards.
Evgeny
Evgeny,
Spider files are databases, in all its versions users can create as many databases they want, each can be as large as user wants, if you can link separate databases this is above what other scheduling software can do out of the box.
My personal struggle is on the way different contractors and subcontractors define their own codes that can be in conflict with other databases. This is why P6 implements the option of codes to be project specific.
Evgeny Z.
Vladimir, I was also thinking, that another option could be instead of deletion to move inter-project link to something like "unmatched inter-project links" category/section.
But any way, this is just me "thinking aloud"
Regards.
Evgeny
Evgeny, at the moment this feature is absent but it is easy to add.
My knowledge about databases is very limited but looks like codes are relational within a single file but as soon as you have separate files there is no such relational link.
As you know there is a special link under project options to consider portfolio during calculations but I do not know how it works, perhaps a one way communication that will pull down some data from portfolio but will not make any changes to the portfolio tables until you execute a consolidation.
Evgeny Z.
Does activity on a project level actaully know, that it has a link to or from on a portfolio level?
I think that the message shall appear only for activities with external dependencies.
Evgeny Z.
Vladimir, understood.
The general message as I understand, is that code change of objects shall be in general avoided.
Regards.
Evgeny
Yes, it is expected bahavior. I think that we shall add warning message but still permit to break the link if necessary. For example with additional information it may be necessary to add details and instead of one activity create several. Only one of them will be used to keep existed dependency. So this activity shall have the same code.
The same problem exist when you compare two project versions. If to change activity code there will nothing to compare with in the previous version.
