P6 Event Code AVAA0-1113-3
Greg Gibbon
User offline. Last seen 4 years 39 weeks ago. Offline
Guys,
I keep getting Event Code AVAA0-1113-3 when I open a schedule which the forces an exit of P6. The schedule has previously been used many times . We are using P6v7 release 3. Any ideas?
Larry Cortez
User offline. Last seen 11 years 50 weeks ago. Offline
Try logging in to the database and run the following query:
select proj_id from project where not exists (select * from projwbs where projwbs.proj_id = project.proj_id);
If you get one of more record returned, then your problem is with orphaned records and we can proceed to that solution.
Larry
litbusiness.com
