Solution for the following Event code AVAA0-1490-1in Primavera 6 Vs 7
Mohammed Wasiuddin
User offline. Last seen 9 years 3 weeks ago. Offline
Groups: GPC Qatar
Dear superiors',
Can any one help me on the following event code error please !
215
This was happend when i was trying to import a file.
Thanking you and Regards
Wasiuddin.
Mohammed Wasiuddin
Groups: GPC Qatar
Thank you very much sir.
But i am trying to import .xer file. Then how i can ????
218
Wasiuddin.
Amit Parmar (PMP)
User offline. Last seen 12 years 16 weeks ago. Offline
Hi Mohammad,
If you are trying to import an excel file or MSP file the solution is as follows :
Importing / Exporting MPP or MPX File
AVAA errors received when importing or exporting a file to or from Microsoft Project are commonly caused by lack of permissions to the Project Management install directory, the default path is \Program Files\Oracle\Primavera P6\Project Management.
When importing or exporting P6 writes a log to this directory if the user does not have Read / Write access to this directory, an error will be thrown.
Solution
Grant Read / Write access to the directory, by default: \Program Files\Oracle\Primavera P6\Project Management, for the user.
Importing from Excel
AVAA errors when importing from Microsoft Excel, are specifically related to data within the Excel file.  The file may contain activity ID's that do not exist in the project.
Solution
Check the Excel file and verify that any Activity ID's in the Excel file exist in the PM project the file is being imported into.
The above solutions are from Primavera.
Hope it helps
Amit Parmar
http://www.primaverablog.in
