P6 Version 8.2 vs Microsoft SQL database server 2005
S
siva ganesh 👤 Member for 14 years 6 months
Hi everyone,
I was working with P6 V6.1 with the Database Microsoft SQL server, now i have updated Primavera to Version 8.2. When i run the Primavera program the database is not supporting. The report comes as:
The application and database versions do not match.
Click Exit to close the application.
Primavera P6 Professional R8.2 8.2.0
Expected database version: PMDB,0820.0001.0001
Current database version: PMDB,0600.0011.0001
Please help me to sort out. I have more schedules in my old database. I need to recover it.
Hi Michael
There was a bug in MS-SQL server which didn't clean the registry properperly - I hope you used the uninstall feature.
If there is no other software using MS-SQL server check your registry for entries from SQL-server and delete them.
If there was Oracle database I never heard of this issue.
M
michael bengano 👤 Member for 11 years 10 months
hi.gud day..i just want to ask for your help.i want to install the latest version of primavera 8.2. the problem is when i start to install it, it says that i have to delete the older version of primavera to continue installing.but after i deleted the older version, the installation still stops and tells me again to delete the older version?thank you so much.
S
HI chris,
I have installed SQL server 2012 and i uninstalled database engine.
Presently nothing is working out. Whether all my schedules would have deleted?
am scared. my boss will fire me. help me out chris.
Siva
S
Dear Chris,
The report i got was
SQLServer Exception: The TCP/IP connection to the host failed.
Connection refused to the host. Verify connection properties, check that an instance of SQL server is running on the host and accepting TCP/IP connections at the port
Kindly advice.
Siva
S
Hi chris,
I have followed your steps but still have a small problem.
Once i run the bat file, i have been asked few things
Administrative USer name -
Administrative Password -
Database name -
I am not familiar with database problems. Kindly help me sir.
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
