Unable to configure SQL Server database connection for P6 v16R2
16 years 3 months
here is the p6 fix
  1. Create a working directory (c:\tempextproc for example), and place the following code in a file called  getempno.pc
    /* getempno.pc */
    #include <sqlca.h>
    #include <oci.h>
    int __declspec(dllexport) get_empno(OCIExtProcContext *epctx)
    int empno=0;
    EXEC SQL REGISTER CONNECT USING :epctx;
    EXEC SQL SELECT empno INTO :empno FROM emp where ename='KING';
    return(empno);
  2. Open a Visual Studio command prompt (Start > Programs > Microsoft Visual Studio 2008 > Visual Studio Tools > Visual Studio 2008 Command Prompt ,   and move the command prompt into that irectory.
  3. Set ORACLE_HOME and MSVCDIR environment variables by issuing the following at a command prompt (adjust paths for your environment):
    set oracle_home=D:\oracle\product\11.2.0\dbhome_1
    set MSVCDIR="D:\Program Files\Microsoft Visual Studio 9.0\VC"
  4. Precompile the .pc file using the following command (all on one line), which will result in the creation of getempno.c :
    proc iname=getempno.pc oname=getempno.c parse=full include=%ORACLE_HOME%\oci\include include=%ORACLE_HOME%\precomp\public include=%MSVCDir%\include
  5. Compile getempno.c with the following command (all on one line), which will result in the creation of getempno.dll
    cl -I%ORACLE_HOME%\oci\include -I%MSVCDir%\include -I%ORACLE_HOME%\precomp\public -Zi getempno.c /LD /link %ORACLE_HOME%\oci\lib\msvc\oci.lib %ORACLE_HOME%\precomp\lib\orasql11.lib msvcrt.lib /nod:libcmt /DLL
  6. In this case, we'll copy the dll to %ORACLE_HOME%\bin for simplicity
    copy getempno.dll %ORACLE_HOME%\BIN\getempno.dll
  7. At this point, getempno.dll will have a dependency on MSVCR90.DLL which likely does not exist in the PATH, so it will need to be copied to %ORACLE_HOME%\bin, or the following error will result at runtime:
    ERROR at line 1:
    ORA-06520: PL/SQL: Error loading external library
    ORA-06522: Unable to load DLLERROR at line 1:
    First, however, it will need to have the manifest incorporated into it or the following error will result at runtime:
    Microsoft Visual Studio C++ Runtime Library
    Runtime Error!
    Program: d:\oracle\product\11.2.0\dbhome_1\bin\extproc.exe
    R6034
    An application has made an attempt to load the C runtime library incorrectly.
    Please contact the application's support team for more information.
    To create the manifest, move the VS2010  command prompt into the MSVCRT redistributable folder and issue the following:
    cd %MSVCDIR%redist\x86\Microsoft.VC90.CRT
    mt.exe -manifest Microsoft.VC90.CRT.manifest -outputresource:msvcr90.dll;2
    for further information, refer to MSDN Documentation
  8. After incorporating the manifest, copy MSVCR90.dll to %OracleHome%\bin
    copy msvcr90.dll %ORACLE_HOME%\bin\msvcr90.dll
  9. Now, connect in SQL*Plus for example
    sqlplus scott/tiger
    and create the library, create the procedure wrapper, and test it by running the code below
    drop library empnolib;
    create library empnolib as 'D:\oracle\product\11.2.0\dbhome_1\bin\getempno.dll';
    create or replace function get_empno
    return binary_integer as
    external library empnolib
    name "get_empno"
    language C
    with context
    parameters(context);
    select getempno from dual;
  10.
  11. also look at the microsoft fix
https://msdn.microsoft.com/en-us/library/ms235560(VS.80).aspx
