Global Change to show Days as Month Duration>
L
Laura Vass 👤 Member for 14 years 1 month
Hello
Recently moved to high level planning in Months & Quarter duration. Scary as I have come from Hourly Planning!!
I remember from P3 traning years ago that you can create a Global Change, probably with a Text Field Column to show Days into Months? Something like :
Original Duration / 30 = No of Months
Can someone tell me the Global Change Data should run in P6 please?
Laura
Aldrin Morallos 👤 Member for 15 years
Hi Laura,
Try to provide separate 2 Text Column outside or beside OD column containing "Days" copied from OD & "Months" from there you formulate it using Global Change from Original Duration/30 and you'll see the result.
OD- Original Duration.
Thanks.
L
Thanks Raymund for your amazingly quick response.
I did do that one too.
You think away to show 2 columns? Months & Days?
Raymund de Laza 👤 Member for 16 years 7 months
Laura,
Global Change is not needed to show durations into Months.
Go to User Preferences... Time Units... Durations Format.. set Unit of Time to Months
Hope this will help.
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
