P6 saving data confusion
When you change layout after updating data should you save the layout first. I have noticed when you save layout and then go back into the layout later the data (dates) have changed but if you do not save then the changes are ok.
I'm confused because at the training course recently attended the tutor always reiterated not to save the layout when asked but other people have said that you should save!!
Help please as i'm totally confused.
M
Manoj VS 👤 Member for 16 years 11 months
Saved layouts can be retrieved at later stages.
If you have changed some thing to persent layout and saved by over writing present layout youcan retrive layout with latest changes only.
At training your trainer may require the layout which he use for describing later lessons. that may be the reason he told not to save the layout.
Raymund de Laza 👤 Member for 16 years 6 months
Try saving the layout for the Current User Only otherwise all users who uses the same layout may modify them and will of course be different from what you saved the last time.
Hope this wil help.
Anning Sofi 👤 Member for 14 years 4 months
I agree with Alfred posting.
Only, I want to add that  in earlier versions prior to P6 V 7, P6 sometimes or most of the time lost the layout saved after P6 exit.
Alfredo Jr. Hubilla 👤 Member for 14 years 4 months
When you change layout after updating data should you save the layout first.- If you want to retain the old Layout then dont save it but if you want to see the changes try the "SAVE AS" option.
I'm confused because at the training course recently attended the tutor always reiterated not to save the layout when asked but other people have said that you should save!! - Sometimes you dont have to save the layout just to retain your old layout; but if you want the changes that you made to your layout just try the SAVE AS.
Hope this will help.
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
