Update Data date 1st time....
Jenny Ingco
User offline. Last seen 3 years 39 weeks ago. Offline
Dear All....
I have a little problem with updating my schedule data date,, I start load the actual start date to my current schedule for some activities and then update the data data to the current date I moved it 4 monthes, the problem now I got very high -ve TF... So, I am very thankfull for any advises how I can fix that?
Thank you all..
Frederic Fasquelle
User offline. Last seen 2 years 20 weeks ago. Offline
Negative float can either come incorrect finish date of your project (as explained by Hilal), either you have put constarint.
Primary constraints like Mandatory start/finish, "Start on", "Finish on" are deleting your float.
It means that even if you have margin, by applying these constraints, P6 launch calculation considering them as 0 float. Any delay will thus generate negative float,
Frederic
Jenny Ingco
Dear All,
Thank you very much for your great help. I did try to change the finish date of the project it's work ok for overall TF but still have -ve values for some WBS's and I don't want to change the duration also I am talking about 4000 activities. I got TF=-170 so how I can avoid that? Also, I need to know if that commen issue if I show the owner my current schedule with -ve TF?
Thank you again,,
Hlamalani Baloyi
User offline. Last seen 13 years 4 days ago. Offline
can you really avoid negative float? i dont think you can, its a matter of a program telling you where you will not meet your finish date,
Hilal Hallani
User offline. Last seen 13 years 16 weeks ago. Offline
Groups: GPC Qatar
Hello Hani,
I had this same problem when developing a programme. I had negative floats because my finish date in the programme did not match the "must finish by" date in the project details tab. When I changed the "must finish by" date in the project details tab to match the finish date in the actual programme, my negative floats changed to zero.
Hilal Hallani
