P3 to XER Converter
22 years 10 months
P6v7 SP2 is the first version of P6 that did not support P3 schedule import unless P3 or SureTrak was already installed.   This has to do with Primavera complying with the Btrieve copyright.  If you already have Btrieve legitimately installed on your machine (via P3 or SureTrak,) then p6 will use it to import your P3 file.  All versions of P6 prior to Version 7, Service Pack 2 will allow you to import P3 schedules without P3 being installed.
The P3-to-XER converter program is available for free to all registered P6 users with a maintenance agreement.  Just go to https://support.oracle.com/CSP/ui/flash.html and use the Knowledgebase to find and download this stand-alone program.  Good luck!
15 years 11 months
Hi Simon,
I think it is a feature of P6 R8 because a friend of mine has P6 6.2 installed in his computer and this version has the option of import from P3 even if he doesn't have P3 at all. I have P6 R8 in my PC. I will check today.
baris
18 years 11 months
Hi Baris,
I heard from our vendor that a conversion programme exists however it will only work if you use it in conjunction with a licensed copy of P3.  This is why you can't import P3 into P6 unless you have both licensed versions installed on your machine.
Simon
15 years 11 months
I think you can directly import a P3 file to P6 without using a converter. Just follow File-->Import-->P3. Then you can export it as XER if you need a XER file for some other purposes.
baris
