How do you mergre 2 different projects into one project?
Ruel Camaquin
User offline. Last seen 4 years 30 weeks ago. Offline
Guys,
So how do we merge 2 or more different project in a single project in P6? resourcing, cost account and other details will be encoded after the projects were merge.
Thanks in advance PP!
Ruel
User offline. Last seen 19 weeks 6 days ago. Offline
Hi Ruel,
Select all projects you want to merge then Open all at the same time.
On the WBS window, copy the WBS of the projects into the project you want to merges.
Hope this will help you.
Daniel Limson
Ruel,
If you are using P6,  We export the file (Project A) and import the file to Project B using update. This is dangerous if you have similar Activity ID, as it will overiwrite or update any activity with the same Activity ID.
First, you need to make sure that your Activity IDs are unique on both projects. second, use updae rather than creating a new project when importing the file.
Daniel
User offline. Last seen 19 weeks 4 days ago. Offline
Hi Ruel
In Asta Powerproject I would just copy and paste one project into the heirarcy file of the other.
All data would be copied with it - calendars, resources, costs etc.
Of course the main benefit of Powerproject is that is not based on any WBS so that may be a problem.
If you cannot do the same in P6 then that is another good reason for not bothering with it.
