WHAT IS A TECHNIQUE FOR QUICK RESOURCE LOADING IN PRIMAVERA FOR A COMPLEX PROJECT? HOW TO POPULATE PRIMAVERA EXPORTED EXCEL FILE
8 years 2 months
I prefer Nomitech CostOs cost estimator software. You can be Primavera activities with resources from CostOs BOQ items automaticly. CostOs using Primavera API integration successfully.
16 years 3 months
you will have to talk to who ever did the takeoff and made the Budget categories to see what was put into what bucket.
there has to be a basis for this estimate somewhere with sufficeint detail to get the budget numbers
is your company using and estimating tool ? if so you can probally get a detailed export out of it to excel and use that
10 years 2 months
Dear Johannes,
Thanks for the link.
Ali
10 years 2 months
Dear Zoltan Palffy, as you said, “Copy/Paste” Activity ID & Activity Description, into the Resource tab TASKRSRC and then populate with budgeted units using resource name - Very nice I agree, But,
My question here is, in BOQ we have very few items, but, in primavera schedule its huge number of activities. What technique/template do you use to populate this huge Task List (Activity IDs) with resource budgeted units (BOQ).
How do I distribute a single BOQ item to a number of activities in primavera schedule?
10 years 2 months
16 years 3 months
1st create the required resources
create a dummy actviity and right click and select assign resources and assign ALL of your labor and non laor resource to this dummy activity.
next export to excel the activities AND the Resource and Resource assignments
when exporting the file to excel make sure to include the resource type and budgeted units and activity name
you will now have 2 tabs one for the activities called TASK and the other for the resource called TASKRSRC
now copy the activity id and description into the Resource tab TASKRSRC
now use the resource name from the dummay activity to populate the TASKRSRC tab with th ebudget units labor and on labor
Each resource will have to be on a seperate line. So the the same activity maybe listed seversl times.
15 years 11 months
There are no Shortcuts but there would be workaround between Excel and P6.
BTW, what type of Projects? A mass Housing Project or Tower Building?
