How to assign a same resource to all of activities?
6 replies [Last post]
Marco Zargarani
User offline. Last seen 5 years 31 weeks ago. Offline
I tried to assign a same resource (dummy resource) to all of my activities by using Global Change, but it didn't work properly. I think we can only change the resource name in global change, no changes in any assignments. I was wondering if there is any other way to do this?
Mohammad
Tanveer Ahmad Niazi
User offline. Last seen 7 years 16 weeks ago. Offline
Groups: GPC Qatar
Hi 2 all
This is true we can assign resources to multiple activities, but what about the units. Is there any way to assign units to multiple avtivities coz there may be couple of activities consuming same units of resouces.
Tanveer
Zeeshan Jamal
User offline. Last seen 11 years 48 weeks ago. Offline
Dear All,
         After assigning one or more resources to Multiple activities, is it possible to assign same number of resource quantity to all the activities assigned with that resource???
Eg: if i'm assigning a resource 'X' to the activities A, B, C & D and then can it be possible to assign the quantity of X (say 'N') to all the assigned activities A, B, C & D at the same time.
michael ramos
User offline. Last seen 8 years 20 weeks ago. Offline
hi Mohd
yes kumar and sharref are right, if you dont want to right click then click assign first before selecting the rest of the activities
command bar buttons are also available
Shareef Abdul Azeez
User offline. Last seen 4 years 3 weeks ago. Offline
Hello Mohammed,
Kumar is right....!!!!
You can assign multiple reources to group of activties or all activties by : Selecting the activties, then right click --> Assign--->Resources.  Select the resource (or multiple resources using Ctrl + Selection). and Assign.
Best Regards
Shareef A Azeez
Marco Zargarani
Dear Kumar,
It's not gonna happen, because when you select all of your activities, your assignment button will be useless and you can't assign any role or activity to your selection !!!!!!
kumar s
User offline. Last seen 9 years 29 weeks ago. Offline
Dear Mohammad
you can assign the resource to all the resources by just (Shift+select)option.there is no need to go through the global change
select the resouece column in the activities layout and select all the activities and assign the resource which you need at once.
