Assign resources to the same activity more then once
Valerii Buturlakin
User offline. Last seen 14 years 11 weeks ago. Offline
Hi!
I assigned one resource several times to the same activity. When I do export/import (xer-file) several assignments disappear and stay only one. Why? In resource assignments settings I marked that resource can be assigned to the same activity more then once.
Valerii.
Jose Manuel Marti...
User offline. Last seen 27 weeks 1 day ago. Offline
To contribute my two cents,
Open the XER file in a text or notebook editor, then search for the "TASKRSRC" table. Copy all the data from this table into an Excel sheet. In Excel, modify the column for "role_id" and assign a sequential number to each row in that column. Once completed, copy the modified table back into the XER file, replacing the original "TASKRSRC" table. After importing the modified XER file, you will see all your resources properly assigned. By assigning unique values to each row, the system will create different assignments during the import.
JM
JM
JM
JM
JM
JM
JM
JM
JM
JM
JM
JM
JM
JM
JM
Ben Fleury
User offline. Last seen 8 years 16 weeks ago. Offline
@Luca
Thanks, for this post back in 2009. I've successfully used this trick while updating changes to my baseline. Cheers!
Dieter Wambach
User offline. Last seen 8 years 5 days ago. Offline
Luca
Not if you’ll choose the option "Update existing" for resource assignments.
Luca Basile
User offline. Last seen 10 years 11 weeks ago. Offline
Groups: TILOS
is doing, there is a trick to avoid this
if you apply a different cost account for each of the resoruce assignment they will remain, otherwise when import back the XER you will have only one
Hope this help
Luca
Dieter Wambach
Valerii
In the user-manual (PMRefMan.pdf) there is Chapter 6 for Export/Import of data. Your item is in the part "Importing Projects" --> "Import Project Options" --> check for the resource assignments and choose the same option as mentioned there.
Good luck!
