Assign wbs codes fast
Panayiotis Alan age
User offline. Last seen 16 years 6 weeks ago. Offline
Can you please advise me a way to assign wbs codes for group of activities, without the necessity of doing this for each activity?
Arnold Puy
User offline. Last seen 10 years 23 weeks ago. Offline
Hi Mr. David,
If I’m not mistaken, you can’t. "RA" is similar to "SDK" in P3. There is a Dictionary6x for P6. However, there is no WBS in here, only Activity Codes.
There is one more called "PATTLNK_632006_536-xerFileParser&Builder" but a little bit difficult to assign the WBS & Activity Code.
Arnold
David Wallace
User offline. Last seen 4 years 1 week ago. Offline
Can you use ’RA’ files in P5/P6?
If you can why don’t you export the WBS dictionery skeleton to the PROJECT.xls file, fill it out quickly in Excel and then re-import it?
David.
Arnold Puy
You are welcome.
Panayiotis Alan age
You are very correct. Thank you very much
Arnold Puy
Hi Alan,
Welcome to Planning Planet.
You can display the WBS & Activity Code in your Column and use the Fill down (CTRL+E). Or you can even drag/move the activities to the WBS level.
Another thing is, try to export to excel and assign it.
HTH.
Arnold
