Editing the Import datas from Excel
6 replies [Last post]
Haresh Jayanth
User offline. Last seen 6 years 21 weeks ago. Offline
Dear All,
I exported my program from P6 to Excel and input Budgeted cost in excel in Projcost sheet.
After loading the cost, i imported back the file to P6.
But now , i am not able to edit the budgeted cost column in P6.
Can anybody suggest any solution to edit the budgeted cost column??
regards,
User offline. Last seen 6 weeks 5 days ago. Offline
No worries!!!
I’m happy to help.
Smile
Haresh Jayanth
Dear Rodel,
Thanks for solving the problem......I want to learn from u in future.
regards,
Haresh
Haresh,
You are trying to edit a non-editable column which is a summation of Labor Cost, Non Labor cost, Material cost and expenses. If you import a cost using "ProjCost" meaning you used Expenses table. You can edit the cost under Expenses tab on Activity Detail.
Haresh Jayanth
Let me explain again clearly.......
First I exported my P6 program to excel. Then i loaded cost in excel in "ProjCost" sheet and then again imported back to P6.
Now i have cost loaded in "Budgeted Total cost", whereas Project material cost and Project Labour cost column shows no cost.
But now i cannot edit the data in the budgeted total cost column in P6.
Any solution pls..
Ferdinand U.
User offline. Last seen 6 years 46 weeks ago. Offline
Maybe, you are showing the Budgeted Total Cost in the Column?
Show instead the Budgeted Labor or Material Cost in the Column
Haresh,
Are you referring to Expenses cost under Expenses tab? Which project cost column are you referring?
