Automatic Running Number for Activity Id
Ir. P. Jaya Chandar
User offline. Last seen 12 years 23 weeks ago. Offline
Dear P6 Experts,
Is there any easier or straight forward way to re-number the activity ids so that at the end of the schedule development process, we will have a properly sequenced running numbers? At times, we do insert additional activities in between other activities and the end result is a non sequential id numbers.
I noticed that the only way to change the activity id running numbers in bulk is by exporting it out to excel, changing the running numbers there and importing back to P6.
Is there anyway to use global change to automate the running numbers?
Khuong Do
User offline. Last seen 6 weeks 1 day ago. Offline
I write an article regarding How to Renumbering Activity ID in Primavera P6.
Kindly read it here : https://doduykhuong.wordpress.com/2016/05/27/renumbering-activity-id-in-primavera-p6/
Ir. P. Jaya Chandar
Thanks Dieter. Good that Version 7 included the feature.
Cheers.
Jaya
Dieter Wambach
User offline. Last seen 8 years 10 weeks ago. Offline
Jaya
In P6 Version 7 there is such a feature "Renumber Activity ID’s".
Out of P6 Help:
Auto-Number renumbers selected activity IDs based on the sort order of activities in the activity table. The first activity in the sort order is renumbered using the values you type in the Prefix and Suffix text fields. The remaining selected activities are renumbered using the same suffix and prefix, and they are incremented using the value you type in the Increment Value text field. If P6 detects that it would renumber a selected activity ID to an activity ID that already exists, exclusive of those you selected, then the Duplicates dialog box appears. You use that dialog box to enter another activity ID. (end of quotation)
With older versions just the way via EXCEL.
