WBS- SUMMARY DURATION
7 replies [Last post]
Alaa Al haj
User offline. Last seen 8 years 22 weeks ago. Offline
HI
EID MUBARAK TO ALL
does anybody know how primavera 6 calculate original duration for WBS- level when organizing activities by WBS
cause i have 12 W/ H calendar but primavera consider as 20 hours when calculating duration for wbs level
i don’t know why
yours
Alaa
Alaa Al haj
Thanks All
i change the default Global Calendar to match the project Calendar
and now it is ok
i don’t know what will we do without the best planner around the world on this Forum
thanks again
we should be proud of this Forum
yours
Alaa
Arnold Puy
User offline. Last seen 10 years 23 weeks ago. Offline
Hi Neil,
You are right..
It’s okey..
Arnold
Neal Walsh
User offline. Last seen 4 years 40 weeks ago. Offline
*Arnold
Sorry Arnie! :-)
Neal Walsh
Alaa,
This has always been an issue with P6, upto 6.2, and as Arniold states, v7 has its own time periods to correct this problem.
However, on versions prior to this, set your durations to hours and the issue will be resolved.
Walshy
Arnold Puy
Hi Alaa,
Try to use WBS Summary as activity type for each WBS level or to the highest level.
With P6 v7, each calendar has its own "Time Periods" so you don’t have to worry.
Arnold
A D
User offline. Last seen 4 years 35 weeks ago. Offline
at summary level, P6 uses global calendat to calculate duration.
Global calendar and project calendar need to be same to show matching figures
Anoon Iimos
User offline. Last seen 3 years 26 weeks ago. Offline
please check your global calendar
