Reset the progress
David Scott 👤 Member for 15 years 7 months
Thanks Muhammad,
I need to replicate last years outage schedule exactly for this year, then make some modifications from lessons learnt.
I'll have a little mess about with global change, as I need to use the actual durations recorded from last year as the new original durations for this year.
Dave
M
muhammad anwar 👤 Member for 19 years 4 months
Salar,
In order to deprogress a project four things you need to do
1 - Pull the data date to start of the project
2- Set the Actual labour and nonlabour units to 0 by fill down method ( display columns, set first to zero and use fill down for the rest)
3- Set status of activities from progress or completed to ’Not started’ by global change
4- Set Remaining duration ’RD’ to Origianal duration by Global change
Then you almost done
For 3 - Global change
if All of the following
where Activity status is not equal Not started
Then
Activity status = Not started
and hit the change button
For 4 - Global change
Then Remaining Duration = Original Duration
and hit the change button.
Hope this will help
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
