Hiding Blank Acitivity Codes
7 replies [Last post]
Martin McGuire
User offline. Last seen 2 years 32 weeks ago. Offline
Does anyone know how to hide blank activity codes from the layout, currently I get levels with no associated coding stating e.g. No Area/Department?
mimoune djouallah
User offline. Last seen 6 years 13 weeks ago. Offline
Jonathan, you are the man, thanks
Jonathan Russell
User offline. Last seen 15 years 3 weeks ago. Offline
heres a little trick for you guys. add a completly blank code using alt 0160. holding alt and on the num pad key in 0160 then release alt will enter what looks like a space. it does not act like a normal space using the spacebar and will save as a code value.
if you dont have a numpad copy and paste whats between the " below
mike mark
User offline. Last seen 16 years 6 weeks ago. Offline
1. create an activity code
2. assign the code to the blank activity code
3. create the appropriate filter.
4. filter them out.
Ruel Camaquin
User offline. Last seen 5 years 4 weeks ago. Offline
Martin,
Hope this helps,
1. Go to View
2. Click Group and Sort
3. From Groups by Option, check "Hide if Empty" box.
Cheers!
Ruel
Jason LI
User offline. Last seen 5 years 15 weeks ago. Offline
Martin,
I’m not fully get your meaning, but if you can add a filter like Department is not equal to blank. your layout will exclude these items. hope its you want.
mimoune djouallah
there is a workaround, you can put a point or a dash (. -) as a dummy activity codes and assign it to activities without activity codes, it is always better then those ugly no code.
HTH
mimoune
Arnold Puy
User offline. Last seen 10 years 36 weeks ago. Offline
Hi Martin,
If you are using P6.2 then unfortunately you cannot hide the blank activity codes. The best way is to use WBS.
Arnold
