Expense % Complete = Activity % Complete ?
Mohammed Wasiuddin
User offline. Last seen 9 years 30 weeks ago. Offline
Groups: GPC Qatar
Dear superiors
Could anyone suggest me in deatail regarding,in P6/6.2 how can i equal the Expenses % comp. = Activity % comp.
I tried with global change from the subject select area of Project Expenses but it won’t work(i meant to say there is no parameter/value ragarding Activity % complete in the project expenses).
Thanking you.
User offline. Last seen 2 weeks 5 days ago. Offline
create a UDF
then make the UDF % complete equal the expenses % complete
then make the UDF % compelte equal the activity % Complete
Andrew Taylor
User offline. Last seen 4 years 45 weeks ago. Offline
To add to Mark's workaround:
As far as I know, you can't import [Expense % Complete] from Excel to P6. You can however import [Actual Cost].
If you want to match your [Expense % Complete] to your existing [Activity % Complete] you can:
  1. Export both data sets to Excel (Activities AND Expenses);
  2. Use a vlookup to change all [Expense % Complete] values to the [Activity % Complete] value;
  3. Recalculate the [Actual Cost] value using [Expense % Complete] /100 x [Budgeted Cost];
  4. Import the new Expense data to P6.
Now, P6 will calculate the [Expense % Complete] using [Actual Cost] / [Budgeted Cost].
(If this isn't clear let me know and I'll add detail to the steps).
Andrew.
Mark Porter
User offline. Last seen 1 year 22 weeks ago. Offline
Hi Mohammed,
As you will possible be aware, a planner is able to associate multiple expenses to an activity & therefore this is the reason that you cannot use a global change to assign the Expense % complete as the activity % complete. (i.e. Expenses are the children to activities, just like resources are children as well)
To achieve what you are asking, a work around is to export the activity data out to excel with both the expense cost % complete & the activity % complete columns showing, then copy the Expense cost % complete column across to the activity % complete column & re-import back into Primavera.
Hope this helps
Kind Regards
Mark Porter
