Event Intercepted
Z
TONI LUPI
you have lops i your schedule
Follow steps below to fix the issue:
1. Click F9 to get the Schedule window.
2. Check the Log to file option to save schedule details.
3. Schedule the project.
4. View the log, then fix the loops reported in the log file.
Workaround:
By default P6 only checks 10 loops per schedule.In order to allow more loops in the project, set a PM.ini named MaxLoopsToReportCount under Schedule option and set it value which suits the required loops.  It should not be too much so that schedule will take time to process so many loops.
[Schedule]
MaxLoopsToReportCount=-1 (this setting will show all loops)
T
Toni Lupu 👤 Member for 19 years 8 months
Primavera 19.1.2
Error while scheduling
DB : SQL
Error :
an application event has been intercepted. please note the event code for reference
Event code  : SSFII-0822-6
What' the explanation ?  How it is affecting the results ?
Z
esmaeil fadaei
do not steal someones elses thread create a new post and it will be answered this way others can search for this same problem and the solution.
E
esmaeil fadaei 👤 Member for 7 years 6 months
hi all
Primavera 7.0
Error while Removing WBS
DB : SQL
Error :
Event code  : DSEIS-2129-2
Z
Workaround:
[Schedule]
S
Santhosh S 👤 Member for 8 years 7 months
Primavera 16.2
Error while scheduleing
DB : SQL
Error :
[[wysiwyg_imageupload:5182:]]
M
Montasir Abdelhalim 👤 Member for 8 years 8 months
HI
 HERE IS THE COPY OF THE MESSAGE OF THE SAME ISSUE:
*                EXCEPTION  REPORT                  *
Date:          13-Oct-17
Executable:    PM.exe
Application:   Primavera Project Management
Event Code:    AVAA0-1935-0
Message:
  Access violation at address 00830C9C in module
  'PM.exe'. Read of address 00000008
Context:
  1: TfrmMain.actReportsReportsExecute
  2: TfrmWizImport.RunCheckInWizard
  3: TfrmMain.actCheckIn1Execute
  4: TCFormManager.SetToolbar
  5: TfrmLogin.FormCreate
  6:
  7:
  8:
  9:
  10:
Detail:
  Type:        EAccessViolation
  Object Type: TCUltraButton
Components
ORI: ORI Win32 #
ORI/DB: PMDB,0600.0011.0001.0002
IMG: IMG Win32 #1000
System Info
Username: user   Hostname: USER-PC
OS Version: Windows NT ver 6.1, build 7600,  (Intel Pentium)
PLEASE KINDLY HELP ME TO FIX THIS SO I CAN SEE MY REPORTS.
THANKS
MONTASIR
Arnel Lagumbay 👤 Member for 17 years 10 months
Thanks Dieter,
This happens twice in my P6,but now its working fine.I will note it, if it happens again.
Arnel
Arnel
Within that window you have the choice between three buttons - select "More". Within the following window you’ll get more information --> "Copy" --> paste here.
Or ask Primavera or your local dealer. They should have a reference list for those error codes.
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
blake333_
Mohammed Netarwala
Moahmed
S Z
Iftikhar Awan P.Eng.
ahmad rashidi
paulciszewski
