Event Code
Jonathan Ward
User offline. Last seen 12 years 46 weeks ago. Offline
hello,
does anyone ever have this error event code??? I am working in Primavera 6 on a network in another country to the hoste server,,
very very frustrating??!?!??!?!
once again, many thanks, very frustrated in England!
AN APPLICATION EVENT HAS BEEN INTERCEPTED
EVENT CODE AVAA7-2720-E
Jonathan Ward
,, sorry,, that should read,, Replacing a Layout
regards
Jonathan Ward
Robert,
thank you very much for your reply,, and yes your correct,, this seesm to be the issue, could anyone point me in the correct direction of ’Rplacing a Layout’?
Robert Lowe
User offline. Last seen 8 years 35 weeks ago. Offline
I’m assuming you’re dealing with a header/footer error.
If you can change to another layout and edit that section of the header/footer without error, the previous layout is corrupt. You can try to replace the layout.
You may want to try the following. Remove all elements from the section of the footer that is causing the error. You should then be able to close page setup without error. View, Layout, Save then go back to that footer section to make the desired edits without error.
