P6 - Grouping - lots of empty ones. Can I hide them?
DAVID SMITH
User offline. Last seen 11 years 48 weeks ago. Offline
Morning all,
so i have my plan grouped by six different activity codes. A few of them are empy in a few activites. When I go to the ’Group and Sort’ tab. There is an option under group by options to ’Hide if empty’
When i tick the box and click on apply it does not hide the activity codes that are empty in teh group. It just comes up with the grouping saying ’No ’ instead of hiding that group.
Any help on this would be greatly appreciated.
Dave
Mohammad Kaifi
User offline. Last seen 9 years 7 weeks ago. Offline
Yes, You can hide them..within organise window..if ur check box has tick mark..even though ur empty activities codes comes. Just you remove the check box and organise.Again you tick the check box and organise and refresh data. Hope u will get it. Enjoy!
mimoune djouallah
User offline. Last seen 5 years 51 weeks ago. Offline
oh David, i have been in th same situation as you, so you have two choises :
-either export your project to P3.( just to print your program)
-or change your wbs ( whitch is not the best solution).
-just hope that P7 will fix it ;)
HTH
Izam Zakaria
User offline. Last seen 8 years 30 weeks ago. Offline
yup I perfectly agree with Arnold Puy....It was built for WBS only.....
Arnold Puy
User offline. Last seen 10 years 22 weeks ago. Offline
Hi David,
The option for "Hide if empty" is designed for WBS & not for Activity Codes.
You need to use WBS or you can assign all your unassign activities to Activity Codes ID. You cannot hide all unassign activites.
HTH.
Arnold
Ali Farhat
User offline. Last seen 15 years 6 days ago. Offline
you have to set this option "hide if empty" to every level of your group. Most probably you checked it for the first one only
