Long time for opening a project.
O
Oliver Melling 👤 Member for 19 years 3 months
Guys,
We had this problem at my last company and realised that if you have large plans are not purging deletes the database speed will slow down quite a bit.
You will need admin rights to purge deletes but can set it up to do this each time you logout.
Hope this helps.
Ali Farhat 👤 Member for 17 years 9 months
Hi Hannes and Arnold,
I too have the same problem. I recently read a very useful thread in here where you can add a new database. you can use of to store old projects and the other to store current projects.
Arnold Puy 👤 Member for 19 years 3 months
Hi Hannes,
I also have experience this sort of problem. All the same as what you have.
My only solution I’ve found is to export all the projects which I don’t need as of the moment and save them in one Folder and import again the moment I need it. As well as the Sample Project.
Arnold
Featured Partner
Sunchana Johnston
Akram Hammam Mohamed
Sagar Raut
Patricio_aoa
Philip Assou-Dodji
jeoffrey reyes
markg
Manjeet Yadav
Pan
