Primavera 18 opens last opened project upon startup!?
John Reeves
User offline. Last seen 15 weeks 6 days ago. Offline
Primavera 18 opens last opened project upon startup!?  How do I turn this off?
I think I read that it can be turned off in user preferences but that is not correct.  With last file I imported, something went bad.  And now primavera tries to open it when starting Primavera, it tries to read this bad file, sais "bad something" and the program will not open.
If I could get into the program I could delete that project.
Any suggestions?
User offline. Last seen 16 weeks 2 days ago. Offline
do not exit Primavera by clicking the red X upper rigth
ALWASY select file close all.
Also as Santish said you may have to close or delete that last user session.
is this p6 web ?
User offline. Last seen 39 weeks 6 days ago. Offline
You're going to need the exact wording of the error message, perhaps take a screencapture when it appears on screen (Press ALT+prtscn to capture just the active window). Take a note of the error and search for it on http://support.oracle.com
It may end up needing to delete out the last user session record to enable you to log in without a project open.
