Exporting EPS/OBS/WBS/Code Values
Yehya Hayati
User offline. Last seen 12 years 27 weeks ago. Offline
Can any one explain how to export EPS/OBS/WBS/Code Values etc from a well managed P6 and then Import it to the PC at home. Bear in mind the user dont have previlage of administrator.
Means making replica of P6, installed in Office, at home.
regards
yeezee
Arend Kok
User offline. Last seen 10 years 47 weeks ago. Offline
To Export the EPS/OBS structure you will need to use the Primavera API. Wich means using Java...
To get a project wbs however you can just export the project to .xml format, and import the .xml file into access.
That will export the project wbs along with all the other project details.
Hope that helps.
