Activity Code Description values rather than Code Value in Exporting Data
Brian Walkin
User offline. Last seen 51 weeks 4 days ago. Offline
I would like to have Activity Code Description values rather than Code Value when I export data to Excel.
For Example for an Activity Code:
Code Value is Ph1       :         Code Description is Phase 1
I would like to get the description Phase 1, rather than Ph 1. I have to do V-lookups from an external Activity Code table to get the descriptions I need. Is there a was to avoid this step by including it in the export.
User offline. Last seen 17 weeks 3 days ago. Offline
glad I could help you
Brian Walkin
I have V20 and was able to change the option in user preferences to description. thanks
User offline. Last seen 14 weeks 6 days ago. Offline
The code Description values option in User Preference --> Application tab is only available in P6 r20 up. Not available on lower version of P6.
go to edit user preferences click on the Application lab
then under the Codes section under Specify how to display code values
select Description instead of Code Value
now get it how you want it in the tabular area then copy and paste to excel
you can also create a UDF which is user defined field and make it a text value and import these back into P6
then you will have them
