Schedule & Perforemanc % Complete Roll up
19 replies [Last post]
Riyadh Yahia
User offline. Last seen 13 years 28 weeks ago. Offline
Hi To ALL,
I have a Project scheduled on P6, I made WBS for Shopdrawing, Material sbumittal & Approval and Construction.
Then I add resourcs manpower to Construction (WBS) only.
when I start updating i noticed that Scheduled and Performance % complete roll up are showen for Construction (WBS) but for shopdrawing and material (WBS) remain Zero.
I tried to add Labor resource to S.D & M. (wbs) but still the problem is the same.
Can Anyone Help ???
riad
Khuong Do
User offline. Last seen 22 weeks 5 days ago. Offline
I write an article regarding How does Primavera P6 summarize data in the Summary / Grouping Band
You can find out How Schedule % complete and Performance % complete are calculated in Summary band.
Kindly read it here https://doduykhuong.com/2017/07/10/how-does-primavera-p6-summarize-data-in-the-summary-grouping-band/
User offline. Last seen 17 weeks 5 days ago. Offline
Payam and Jose you have to have resources you need a measuring stick
Payam Rezaeian
User offline. Last seen 8 years 8 weeks ago. Offline
Hi guys,
I do have a problem with the Performance % complete in P6 which are not being rolled-up.
Non of the above solutions worked for me. Still in the summary I'm getting zero percent while all of the child activities have been completed and actualized.
Can anyone please help me with this issue?
Payam
Jose Prakash
User offline. Last seen 14 years 12 weeks ago. Offline
Helo all,
Can you explain how to measure the planned % of completion(for the purpose to make the project progress planned curve) in diffrent analysis date from the baseline programme byprimavera 6
Joseprakash
Don Villaflor
User offline. Last seen 13 years 9 weeks ago. Offline
Hi folks,
I'm just a little confuse on how exactly Performance % Complete behaves when it rolls up.
I have all my activities resource and cost loaded but it doesn't rollup. Below are my current settings:
Calculations Tab: $1
WBS: Activity Percent Complete
Advance Scheduling: enabled recalculate assignment
Group & Sort: show total
Any help would be very much appreciated.
thanks.
Don
Riyadh Yahia
Thanx Mark again & again
regards
Mark Porter
User offline. Last seen 1 year 37 weeks ago. Offline
Bugger...
Image and video hosting by TinyPic
Mark Porter
This is my last attempt at getting in a link:
Primavera
Mark Porter
Mark Porter
This should do it for you
Riyadh Yahia
Dear David,
May you explain more.
Thx
riad
David Kelly
User offline. Last seen 3 years 12 weeks ago. Offline
Riad,
Remember there is a switch at the project level in the "calculations" tab, where you can assign all uncosted resources at £1.00. This is good practice if you do not use P6 for resource costing...
Riyadh Yahia
Hi to David,
Thaaaaaaaaaaaaaaaaax David it is done, Thanks to Mark TOO
best regards
riad
Mark Porter
Very well done David, I forgot that I’d also experienced the same issue due to a lack of $/unit associated with the resources. Pretty certain that the same issue applies when trying to view the resource usage on the web application
Mark
David Kelly
The answer is (expert here) that performance % complete is based on money NOT manhours. So all of your resources need costed. If you price them at £1.00 then performance % complete is the Manhour liquidation.
In addition by default primavera does NOT recalculate assignment costs when scheduling by default (you need this) so either recalculate assignment costs under the "tools" pull down, or switch it on under scheduling options (recommended)
Riyadh Yahia
Hi Mark,
Thx for ur Reply, I will try ur comments, I will let U know the result soon.
Thx again.
Riad
Mark M
User offline. Last seen 14 years 42 weeks ago. Offline
Riad
If you have added/deleted activities since creating the baseline, you will get the problem of performance & schedule % complete not rolling up. I would suggest updating the baseline to capture any new activities/deleted activities.
Mark
Mark Porter
You should check the technique for computing performance percent complete set in the earned value tab of your WBS settings, it should be Performance % complete based on activity % complete
% complete should roll up the in the performance % complete column (But not Activity % complete)
Riyadh Yahia
Experts, now 17 Viewers, No Answer!
Kindly do Help me.
THX
