Copy one column of a project to another??
arun kumar
User offline. Last seen 16 years 18 weeks ago. Offline
I have two different project in P5.Now I want copy one complete column of one project to another project or i want to use the same column in both project .
Can anyone help me??
Arun
arun kumar
ya this is what i wanted..
its not possible in Primavera.
ok...
DANG CORP
User offline. Last seen 9 years 24 weeks ago. Offline
Hi Arun,
i know what u mean,
You wanted:
to copy UDF (user defined fields) of text UDF
from PROJECT 1,,, to project 2.
Answer:
No, u can’t do it in Primavera.
even global change can’t do at PROJECT LEVEL.
OTHER OPTIONS
One:
learn the Primavera SDK or API
(if you have not heard of SDK or API) call up the Primavera for assistant.
Two:
go to this website and download the software and it does what u r after.
www.dangcorp.com/toolbox.aspx
Vu Dang
shiv rao
User offline. Last seen 12 years 30 weeks ago. Offline
Can you clarify with what you actually want.
give specific examples and then i think we can help you .
like you want to copy a set of BL1 finish dates from one project to other ?
Shiv
arun kumar
Dear Andy
column is not a code field.Its just a text field.How can it be displayed in common layout & used for other project also?
Arun
Andrew Dick
User offline. Last seen 9 years 6 weeks ago. Offline
Arun,
If the column is a code field then it should be possible if the activity code is set as either a global or EPS code.
Not knowing what type of data you wish to use could you provide more info?
It could be just a matter of ensuring that the column is displayed by slecting it in a common layout.
Give us a bit more to go on.
Andy
