Import Used Defined Column from MS Project To P v5.0
arun kumar
User offline. Last seen 16 years 29 weeks ago. Offline
I tried to import schedule from MS Project to P v5.0.
All other columns are imported except user defined Columns
Also I am unable to import activity codes.
How can I import user defined columns & activity codes??
Can anyone help me????
DANG CORP
User offline. Last seen 9 years 35 weeks ago. Offline
hi Arun,
activity code should work,
try sending it to one of your mates and see if he gets the same result as urs PC.
and play around with the settings,,,
- also, if that fails, send it to Primavera
and see if they can import the thing u r trying to import,
cause did u know u pay them maintenance, and they are quite helpful in these things.
--- alternatively, and last resort, cause i dont recommend u to buy my tool, if u r going to load one off,
but if it is a regular thing that u r doing,
then check this url out. --- download the working version, cause this tool can assign codes in seconds mate.
www.dangcorp.com/toolbox.aspx
arun kumar
Dear Vu Dang
I tried to import.All columns & fields are imported
including user defined.However not getting activity codes.
arun
DANG CORP
hi
it should import from MS project ok.
- go and check the import configuration to make sure that you have mapped the MS proj field to go into P5.
- regarding activity codes, that should come ok,
check ur import settings to make sure that is set to create. not ignore or similar.
i do have another solution, which is my Tool,
but you dont need to use it for this purpose of importing MSP. cause its a standard fucntion, it should work
cause u r importing from MSP, which it should work!. know what i mean.
Vu Dang
www.dangcorp.com
