Import user Define Column from MSP to P v5.0
arun kumar
User offline. Last seen 16 years 5 weeks ago. Offline
I tried to import schedule from MS Project to P v5.0.
All other columns are imported except user defined Columns
Also I am unable to import activity codes.
How can I import user defined columns & activity codes??
Can anyone help me????
arun kumar
Thanx Wambach ..Its working
Dieter Wambach
User offline. Last seen 7 years 31 weeks ago. Offline
Hi Arun
As P5 is a release status of P3e, you’ll better put posts related to P5 into that category.
For the user defined fields (=UDF): First define them in P5. Then, when you’ll start the import, in the 4th(?) window "Template" you can add a new template or you can just modify an existing one. Walk through the detail tabs. The right one is for the UDF. There you can select source and target field.
As for the codes I sorry, I don’t know.
Good luck!
