IMPORTING FROM P3E 3.5.1 TO P5
Dieter Wambach 👤 Member for 19 years 6 months
Hi Suresh
It must be a normal Editor: Notepad (--> see David’s post), Editor, or Wordpad. Never use a wordprocessing software (Word, Open Office, WordPro...), because this will add many control blocks, formatting and others. The XER-file would be destroyed.
Only work with a copy!
David Forrest 👤 Member for 24 years 7 months
XER can be opened with Notepad. This is useful for doing quick integrity check prior to importing projects from other databases.
S
Suresh Sankarankutty PMP 👤 Member for 19 years 11 months
Hi Dieter
Could you pls explain me on which editor we can open the xer file. Do you mean like MS Word or something ?
Pls explain in more detail.
thnx
Suresh
Hi Suresh
Some time ago I had to import 2.1-files into P5. It worked with a small trick.
Primavera by default only allows to import from the previous version. 2 things to be done:
1. The information by which version the xer was produced is in the first line. You’ll modify 3.5 to 5.x - your version.
2. Check if a group name was modified. I don’t believe this is the case. If yes you’ll change it to the new name.
(In the bove mentioned case I had to do it.)
You can open a xer-file with any editor.
Featured Partner
MR JUDE C ANYAEGBU
GeoVe
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
