freezing project file
Onny Ryan Suksmono
User offline. Last seen 8 years 38 weeks ago. Offline
Is there any way to freeze some of project files which underneath the same EPS. For example, I had A, B, C, and D project files under the same EPS and I would like to freeze file A, B, and C from the other users so that they can only view file A, B, C and left access to the file D.
Thanks in advance,
Onny
Onny Ryan Suksmono
Thanks a lot Andy.
It was solved by creating new OBS elements and assigned this OBS to the particular project file then changing the users profile from menu bar.
Onny
Andrew Dick
User offline. Last seen 8 years 31 weeks ago. Offline
Onny,
What you would need to do is set up an OBS structure that supports this theory.
Then you assign the various users to the applicable OBS elements, with the required access rights.
If I’m worng I’m sorry but that’s how I remember it.
Andy
