to import excell files(.xls) to P3e
shaerah rahman
User offline. Last seen 14 years 3 weeks ago. Offline
im having problem to import .xls files to P3e. The problem is on the ’Import project options’. Please.
K D
User offline. Last seen 16 years 25 weeks ago. Offline
Hi shearad.
Could you elaborate your problem sothat we can help you better?
Donny Lai
User offline. Last seen 7 years 13 weeks ago. Offline
Ms. Shaerah,
Also could be due to requirement in P5 (the correct terminology apparently) of having superuser access to import. Cheers.....
David Podmore
User offline. Last seen 13 years 12 weeks ago. Offline
My advice is to start by exporting a small sample representative of the data you wish to import. This gives you a template XLS file into which you can cut and paste your required import data. Unfortunately, this is not as simple as it sounds. You need to ensure the Excel data is in the same format as that exported. Also, when exporting/importing relationships and resources etc, the export produces multiple tabs (sheets) in the one export XLS file. Thus, all tabs must be compiled correctly. E.g. there is one row of data for each relationship for a single task.
Again, export to XLS and see what I mean.
