P6 on a Citrix Network
11 replies [Last post]
Oliver Melling
User offline. Last seen 5 years 5 weeks ago. Offline
Groups: The GrapeVine
PPlanet,
My company is planning on moving 15 standalone P6 licenses
onto a server.
We need the ability to access P6 remotely and also want the
ability to use the web interface to show performance.
Does anyone have any experience of doing this? Is a seperate
web license necessary?
Imran Arshad
User offline. Last seen 6 years 7 weeks ago. Offline
Dear Oliver,
Yes u can check out files remotely.when u linked with p6 remotely,u actually linked to main server which enables u to do things u want but as Dieter said it again depends on rights u have authorised from the IT-Staff.
Dieter Wambach
User offline. Last seen 7 years 28 weeks ago. Offline
Hi Oliver
this is a question to your IT-staff.By standard, export/check-out goes to the local server - which is the Citrix-server. But this can be modified. Unfortunately I don’t know how to do it.
Oliver Melling
But can you check a project file out?
Imran Arshad
Dear Oliver,
You can access every thing within P6 directly & remotely.
Oliver Melling
But you won’t be able to check files out during remote access i believe?
Imran Arshad
Dear Oliver,
I am using P6 directly & remotely with the same user name & password.
Dieter Wambach
Hi Oliver
as the licence is kept on the server it is independent from direct or access via citrix.
When we upgraded from P5 to P6, some basic features of myPrimavera (or whatever name the web-based tool currently has) was included.
John Raper
User offline. Last seen 9 years 1 week ago. Offline
Oliver
I don’t think any new licence is need for using the web. We are about to upgrade stand alone P5 to Citrix enabled P6. This will give the option of accessing P6 from any company PC without it being installed locally.
Hope this helps
John (ex UK Nirex!)
Oliver Melling
Imran,
If i misunderstood your post then,I think a seperate license is required to post project info via a website dashboard on P6.
Oliver
Oliver Melling
Imran,
I think you can pay more for an un-named license, but i din’t think 15 planners could work on that license at the same time!
Imran Arshad
Dear Oliver,
You can access same license remotely.There is no need to buy a seperate License.
