Test plans or reports for P5 deployment using Citrix
Miles Pedder
User offline. Last seen 18 years 34 weeks ago. Offline
Does anyone have any test plans or performance reports for system testing P5 software performance across a WAN using Citrix. We are installing P5 and MyPrimavera across multiple user sites around the country and want to benchmark test system performance and user response times.
Marcio Sampaio
User offline. Last seen 11 years 46 weeks ago. Offline
And do u know if it’s too expensive? And if it generates kind of problems during - or after - installation?
Regards.
Marcio Eduardo.
Gordon Blair
User offline. Last seen 6 years 24 weeks ago. Offline
As your V5 will be sat on a server and you will be technically logged on to that server (via CITRIX), the only real point of vulnerability should be the CITRIX connection itself.
Depending on the version of CITRIX you’re running, you’ll have a time out lag value of around 2 seconds (give or take). Providing your WAN Pipe is large enough for the other traffic you’re shoving down it, you’ll be fine.
Would be interested to hear how you guys get on, though (used to do that sort of thing in a previous, happier, life.. ;o))
Rajeev Nelliyodan
User offline. Last seen 8 years 19 weeks ago. Offline
CITRIX is the software that allows users to access the deployed application on server.Instead of loading P3e/c (Project managment) software on your desktop the application is loaded on the Server.You will access the application through the Citrix thin client software.All the processing is done in the server and you will just see the screen and the only process in desktop is keystrokes.
The advantage is speed on processing comparing to a normal PC to Database server connection to Server to Server connection.
Citrix uses it’s own packet (ICA packet) it’s own encryption (ICA encryption, using a public / private key algorithm.
This much faster and secure.
thanks,
Rajeev
thanks,
Rajeev
Marcio Sampaio
Sorry,
What is "CITRIX"??
Regards.
Marcio Eduardo.
Rajeev Nelliyodan
We are also testing.The initial response is good comparing normal client - server configuration.Please note that it is important that the citrix server to P3e/c database (PMDB) connection should be good.
