A new playground for Primavera software in Vietnam
8 replies [Last post]
Khuong Do
User offline. Last seen 17 years 35 weeks ago. Offline
Sory the site still in construction.
Khuong Do
Hi Rodel!
THanks so much for your information.
We are tirelessly identifying the problem. Our friends though out VN login for testing but do not encounter any virus/trojan detection.
We are trying to figure out the real problem.
Thanks so much for your support.
Khuong
User offline. Last seen 17 weeks 6 days ago. Offline
Khuong Do,
We are still experiencing virus detected on your website. Below are the message found by Symantec auto-protect scan.
Scan type: Auto-Protect Scan
Event: Security Risk Found!
Threat: Trojan.Exploit.131
File: C:\Documents and Settings\UKG\Local Settings\Temporary Internet Files\Content.IE5\8XARGDUF\ms07-017[1].ani
Computer: UNITED-ABF
Action taken: Clean failed : Quarantine failed : Access denied
Date found: Monday, 27 August 2007 3:32:14 PM
It your site is not safe at all... it become useless and my advise is to check and monitor it closely before advertising it.
Rodel
Khuong Do
Hi Dieter
Thanks so much for your valuable information.
We are analysing the problem and will inform to all after fixing it.
We are appreciate for any other virus/trojan encounter situation from you to have a better look at it.
Thanks to all
Khuong
Dieter Wambach
User offline. Last seen 8 years 3 weeks ago. Offline
Hi Khuong
I got the following message:
VirusScan Enterprise: Die Datei C:\Dokumente und Einstellungen\dwambach\Lokale Einstellungen\Temporary Internet Files\Content.IE5\TOOROD5H\index[1].htm ist mit dem Virus JS/Downloader-AUD Trojanisches Pferd infiziert.
I’m sorry for German: Name of Trojan: JS/Downloader-AUD within directory TOOROD5H.
Later I wasn’t able to work with MS-Word.
Solution: IE --> Extras --> Options --> General --> Delete Temporary Internet Files. Then I was able to work again.
Good luck and give a notices, please, after you solved the problem. I won’t access before.
Khuong Do
Dear All
Thanks so much for your idea. We are really appreciate it.
We will try our best to solve each problem you faced.
Cause of the bottle neck of internet bandwidth between VN and wordwide , so for temporary the speed is slow. We will try to set up a mirror server outside VN.
For the virus problem, I have checked with the server administrator. They said that could you guy remember the name of the virus/trojan which was detected. We will define the problem easily.
In VN we have tested and no virus was found. I asked my friend to login and check but they did not face the problem. We will check it carefully.
We are tirelessly improving our forum to give the best.
I would like to say Thank to all of you.
Thanks & regard
Khuong
Andrew Dick
User offline. Last seen 9 years 17 weeks ago. Offline
Khuong,
I would suggest that you need to clean up your site before many more people try to use it as it will fail if people get a virus, because they just wont go back.
Best of luck
Andy
Mangesh Khuspe
hi
khuong
ur attemp is definately nice, but solve the virus problem
first
second its too slow.
best of luck to you.
cheers
mangesh
Dieter Wambach
Hi Khuong
Good luck for your forum.
But maybe you’ll solve one issue first: When I tried to access it, the virus scan was shouting due to a trojan attempt to spy my pc?!
