Primavera Management Softwares (PMS)
Forum Guest
User offline. Last seen 42 weeks 15 hours ago. Offline
Do you know how many threads have been posted in this forum?
... at least 113 persons submitted questions about a problem in a single PMS (Primavera Management Softwares). Is it too much for a $3,000 software? What do you think???
Probably Primavera Support is not good enough... or it is simple or faster to solve a problem in a forum. Some persons can tell you that you do not know how to use PMS and you need a trainning... This is not the real solution to problems. If I pay a lot of $$$ for a "good" software, also I expect the software makes the work easier.
That isn’t the case with PMS. What can you tell about a company with some management softwares, and these softwares can’t be compatible between them? It’s ridiculous.
Take Microsoft as an example. Probably their management software is not the best, but at least it is compatible with other programs and it is not too expensive.
It’s a reality that Primavera have problems with thier softwares. Numbers can tell you so. A lot of questions = a lot of problems. Or all of us (customers) are a bunch of ignorants that must take a trainning to use PMS.
Primavera needs to improve their platform and their vision. I feel that Primavera is doing a research with me but also I have been financing the research. I feel that I have a "placebo" as a management software.
Can you express your feelings??? What do you think???
JT ("I have a dream..." Martin Luther King)
Alex Wong
User offline. Last seen 12 years 7 weeks ago. Offline
Groups: TILOS
Can we have some real example Please
Forum Guest
Dear Alex;
I will answer you back
Why microsoft have to run training course to certify their network specialist you wonder why??
"Ok, every software developer has to get training and make some persons "specialist" to solve problems. I’m not saying Microsoft is perfect; neither is I trying to defend them. Every software has it problems, but Primavera does a Home Run. It is not the quantity of questions about PMS, it’s the time passed between every question."
Software is only a tool, the user is the driver - That have to be clear, don’t blame the tool if you cannot drive it.
"Take this as an example, if you are taking a class or training and anyone in the group can understand what the professor or teacher is saying, who is wrong, the teacher or the students??? That is the same case as PMS. The teacher (PMS) is asking us (students) for information, as a real exam. We answer with the knowledge acquired with the teacher but the results aren’t what we expected. Who is wrong, all of us or PMS???"
Day 1 of my implementation of a PMS, I said to the senior management, have a PMS do not equal to a total Project Management Solution, Process, procedure, people is far more important like having a wrong driver in a right car.
"Do you have knowledge about Ford Explorer’s Firestone tires problem? The case was that drivers had many accidents by car’s tires fault. Ford expended some million dollars to replace Firestone tires for others to prevent accidents. Now, what do you think, the driver was wrong or was the car? I don’t think the driver was in the right car”
Compatibility - SQL & Oralce is the most common DB in the market??
"Try to export a project from Primavera P3 to Primavera P3e and tell me what happen. Both softwares are from Primavera, the difference is only the last "e" in the product name and the result is something strange".
A good CM should elminate lot of the problem and issue in the first place.
"How can I do this?"
Yes, that why we have to move on and improve ourself.
"Yes, but do it as soon as you can, please".
Forum Guest
[Immature statement deleted by Moderator.]
Forum Guest
I understand the car is wrong!!!!!!!
Alex Wong
Groups: TILOS
Dear Forum Guest,
I will try to answer your question
"How many people can claim they understand MS Excel, Access, My guess is almost everyone, but it is truely the case?? Why microsoft have to run training course to certify their network specialist you wonder why??"
"Software is only a tool, the user is the driver - That have to be clear, don’t blame the tool if you cannot drive it"
"Day 1 of my implementation of a PMS, I said to the senior management, have a PMS do not equal to a total Project Management Solution, Process, procedure, people is far more important like having a wrong driver in a right car"
"Compatibility - SQL & Oralce is the most common DB in the market??"
"A good CM should elminate lot of the problem and issue in the first place"
"Yes, that why we have to move on and improve ourself"
