Excel imports
David Shaw
User offline. Last seen 14 years 10 weeks ago. Offline
Is there a quick way it import a WBS structure from an Excel spreadsheet?
hamed planner
User offline. Last seen 18 years 7 weeks ago. Offline
David as Oliver Said chek the Help , But also remember you need to have a superuser access in order to import an excel file , first try to do a sample wbs in Primavera then export it after copy paste your existing from excell in order to make sure it matches with coding and etc.
good luck
Oliver Melling
User offline. Last seen 5 years 40 weeks ago. Offline
Groups: The GrapeVine
Check in the Help function under ’Modifying and importing data from an XLS file’.
It tells you about mapping your headings in your xls spreadsheet with those found in P3e and also goes into more detail about importing from Excel spreadheets.
