Summarization % of Base Line for P5
Omar Abdull Sattar
User offline. Last seen 12 years 21 weeks ago. Offline
for P5 I can not see the Summary% for the Baseline when I am trying to make comparison with the actual. By the way I can see BL Original Duration , BL Start & BL Finish Date in the Summary Band and also I can see all BL percentages for all activities except the summary band is coming Empty for WBS or Activity Code Summary.
Karim Mounir
User offline. Last seen 10 years 37 weeks ago. Offline
Hi Omar,
Checkout this post:
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=8&Top=30849
it may helps.
Karim
Omar A.S.
User offline. Last seen 18 years 3 weeks ago. Offline
Dear IC Quiamco
Yes I mean Unit% & Duration % and another things BL Remaining Duration in Summary
Omar A.S
IC Quiamco
User offline. Last seen 14 years 11 weeks ago. Offline
Check what percentage column are you using. In the list of available % column two does not have summary (Activity & Physical % Complete).
Commonly use Duration % column.
