Import P3 to P3e
M
Marcio Sampaio 👤 Member for 20 years 8 months
Hi Steve Keys;
See Primavera’s response:
Solution ID: prim833
Error: "Unknown error reported by P3 engine"
Version(s): 4.0, 4.0, 4.1, 4.1, 5.0
Fact: Importing a P3 project into Project Manager.
Fact: Exporting a project from Project Manager to P3.
Problem: Error: "Unknown error reported by P3 engine"
Fix: Reboot client workstation and try again. If installed under Citrix, reboot server.
Fix: Btrieve must be installed on the machine and the user must have full rights to the Btrieve Technologies folder and the Primavera folder in the registry.
NOTE: Always backup the registry prior to editing. To back up the registry, click on Registry, Export Registry File, and choose where you would like to Save it to (i.e. Backup folder), give it a name, (i.e. Regback), and click on Save.
1. Log in to the machine as a local administrator.
2. Run Regedt32 (Go to Start, Run. Type in regedt32. Click OK) Go to \HKEY_LOCAL_MACHINE\Software\Btrieve Technologies.
3. From the Toolbar: click on Security,Permissions and give the local users group Full Control of this key.
4. Go to \HKEY_LOCAL_MACHINE\Software\Primavera.
5. Click on Security,Permissions and give the local users group Full Control of this key.
Possible Additional requirement:
If the above changes do not resolve the issue, check the permissions for the ’windows’ folder. If no access is allowed, change the ’Btrieve Home’ folder.
1. Select, start, Run or find
2. launch the ’W32MKSET.exe’ application.
3. Set the ’Home’ directory’ to a folder to which the user has full access:
I didn’t understand anything!!!
Kind regards
Marcio Eduardo
S
Steve Keys 👤 Member for 20 years 10 months
There could be a variety of drivers here; this sounds like a technical support issue and I suggest you contact either your local dealer’s support facility or else Primavera direct.
A profile of Primavera’s support capabilities can be found at http://www.primavera.com/customer/index.asp. You will need your serial number to hand when making contact (it will also need to be under current maintenance).
Good luck.
Featured Partner
MR JUDE C ANYAEGBU
GeoVe
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
