Compare progress
Marcio Sampaio
User offline. Last seen 11 years 50 weeks ago. Offline
Dear all,
Just to know if i’m using right columns to compare planned progress with actual progress. I select "Bl Activity % Complete" and " Activity % Complete".
I think it’s correct - by the explanation on "hint help" - but i’m in doubt becouse of explanation of "Bl Physical (Units / Duration) % Complete" that says:
"... The Physical (Units / Duration) percent complete reflects the actual progress made on activity’s work product so far ..."
Sorry, but i can’t understand this explanation by "hint help".
Do anyone have some comment about it?
Regards.
Marcio Eduardo
Marcio Sampaio
Amar,
I understand that Bl activity % Complete is how much activity must have progressed - until the actual data-date - based on baseline.
If it’s correct, i can use it like a planned progress and compare with "Activity % Complete".
Tell me if u agree.
Regards.
Marcio Eduardo
Amar Aghana
User offline. Last seen 17 years 1 week ago. Offline
Marcio, there is one more thing to understand. That is Performance % Complete. Please try and understand. I have some tips. But I am experimenting. Let me share with you once I am sure. Thanks, Amar.
Amar Aghana
Marcio,
I too had same problem. When you change Activity % Complete, based % Completion type (Physical / Duration / Units), the appropriate % will be considered.
For eg, if an activity % Completion type is Physical when you enter Activity % Complete as 5%, Physical % = 5%,
But I am not able to understand how you have % Complete in Baseline.
Regards, Amar.
