No change in scheudule after "Update Existing" xer import
wullie hendry
User offline. Last seen 7 years 49 weeks ago. Offline
I update a subcontractors schedule every week and normally everything goes OK.  I have been doing this for over 1 year every week with the same settings and had no problems until around 6 weeks ago.  Now when I import the xer nothing changes, I do not receive any error to notify me and the import appears to be normal until checked.  When I import the xer as a new file I can see the update has been done correctly.
This problems occurs with version 7 "update existing" import.  I have not (nor has he) changed the version etc or any other factor that may affect the import.
Has anyone else encountered this?  I can not figure out why this is happening.
Thanks in advance
User offline. Last seen 23 weeks 5 days ago. Offline
check the import settings change ALL of the setting to insert new
also if this is on a server make sure that your access rights did not change
wullie hendry
Zoltan
As stated the settings have been the same for over a week.
The import does say it has completed and nothing changes hence the reason I have a problem.!
I am confused you say nothing changes and then you say the update has been done correctly
double check the import settings
