Assigning Colors/Patterns to Activity Bars in P3e
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
Neil Atkinson
Trian Asmoro
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Rashid is right Scott, this is the mechanism to do it.
It works on any type of bar with any possible combination of filters.
The best way is to take it from the top down because a lower row will automatically overwrite the rows above it. So, for instance, if all normal activities have a green bar, adding a new line below that will overwrite the green bar if it matches the criteria you set in your filters (like: normal and activity code XYZ containing value ABC)
Good luck!
Niek.
Ill give it a try. Will this work for individual activities or just summary bars?
Thanks.
Hi Scott,
Nowadays, I am also trying to learn P3e and have recently managed to get this P3 thing done in this new software.
Make a new bar, and attach a filter to it which screens out the desired code. And then format the bar as you wish.
Rashid
