gantt printout to pdf
mike menlow
User offline. Last seen 12 years 46 weeks ago. Offline
i am trying to print a gantt chart to a pdf file
i am doing a file, print setup, changing driver to pdf, selecting 11x17 format
for some reason it is just printing the item descriptions and column info but not any of the time scale info to the right of the columns
does anyone know how to have the timescale also included in the pdf print file ?
mike
Michael Lepage
Perhaps a silly question.  Does the Activity Layout you have set on your Activities screen have the Gantt chart open?  If not, turn the Gantt on.
On File -> Print Preview -> Page Setup -> Options tab  check that you have the Gantt Chart box checked.  This is also where you set the timescale as the other folks have mentioned.  You may want to remove the "all columns" check - just play with it.
If you can't see it in the print preview screen, then it won't end up in the pdf.
Bullzip is another nice pdf printing app that I use and recommend.
Let us know here if you got it working, with the solution for others.
M
www.planacademy.com - Realworld Tutorials for Realworld Planners
Gün Göksu
User offline. Last seen 2 years 31 weeks ago. Offline
if you see the preview fine then this could also be related to the program you use to get pdfs.
"Foxit pdf creator", "pdfcreator" and "qpdf" are some of the programs I use to get pdfs. they usually work better than the adobe print driver.
hope this helps.
Gün.
Shah. HB
User offline. Last seen 1 year 9 weeks ago. Offline
Hi mike menlow
Check the page setup option ,in that change the time scale setting option to fit your program for example in start date field DD-2M and in the finish date field FD+2M
Footnote
M-stands for months
FD-Finish Date
DD-Date Date
shahul
Gary Whitehead
User offline. Last seen 5 years 37 weeks ago. Offline
Mike,
Go to file, page setup and check that the "bars" option is ticked
If this doesn't do the trick, I'm out of ideas. -Is it only happening when printing to pdf? Does the print preview look OK?
