P3 convert to PDF file
17 replies [Last post]
Aleli Florencia M...
User offline. Last seen 16 years 48 weeks ago. Offline
Hello! Please help. How can i convert a P3 file to a pdf file? thanks in advance.
David Bordoli
User offline. Last seen 9 years 11 weeks ago. Offline
Hi all...
Have a look at
http://www.astadev.com/news/Articles/individual_article.asp?id=119
It is an article about PDFs and Powerproject, but in reality is a good synosis of some of the avialable free PDF drivers around.
David
Jose Frade
User offline. Last seen 4 years 17 weeks ago. Offline
Hello Aleli
I had the same problem printing to Adobe Acrobat in the past.
I simply followed the suggested method available at Primavera.com and solved the problem.
If still not working with you, let me have your email and I’l send a few more tips.
BR
JMFrade
Ian Wilkinson
User offline. Last seen 14 years 6 weeks ago. Offline
The PDF Cute Writer is available at:
http://www.cutepdf.com/Products/CutePDF/Writer.asp
Charleston-Joseph...
Hello,
I use PrimoPDF. This is also freel download available in the internet. Same with others, make PrimoPDF your default printer. Go to print setup. Everything ok. Click print icon.
Best wishes to all
X Planner
User offline. Last seen 9 years 21 weeks ago. Offline
Hey,
try to use cute pdf writer, works fine with me
hope that helps,
Mirza Imam Baig
User offline. Last seen 7 years 6 weeks ago. Offline
Hi, Aleli Florencia Marquez.
Use Acrobar Distiller to print your P3 file. It will convert into PDF format. Hope it will solve the problem.
Imam Baig
Planning Engineer
Ussama Morad
User offline. Last seen 7 years 44 weeks ago. Offline
Install SP3 for P3 V3.1 , this will solve the problem.
Fritzie Lou Lapin...
User offline. Last seen 13 years 24 weeks ago. Offline
Hi!
Don’t Print at Print Preview mode. After checking the margins and pages, go back to the P3 environment then just directly click the print icon. To do this, Acrobat should be the diffult printer.
Lorenzo Aquino
User offline. Last seen 5 years 22 weeks ago. Offline
I have a similar problem too before, whenever I convert into PDF file, the text is garbled. One of my friend send me a procedure to fix the problem. Let me know your e-mail adress and I’ll share you the procedure.
Paul Maddocks
User offline. Last seen 3 years 4 weeks ago. Offline
Aleli Florencia Marquez,
I’ve had similar problems when printing to PDF.
You need to make PDF the default printer first and then print in the normal way.
Another P3 Idiosyncrasy.
Raj Maurya
User offline. Last seen 4 years 5 days ago. Offline
Try to print on adobe pdf printer without changing the path(use the default path and file name). Some times when you change the path the error message comes. Or you select Adobe pdf printer as default printer for your PC then try to print and I hope this will work to produle PDF file.
Jonathan Kirby
User offline. Last seen 1 year 17 weeks ago. Offline
Printing problems often occour when P3.1 is initially installed. There is a fix for it from primavera, see also the readme files on your cd.
But, this is a general printer error, so if you can print to normal printers , it is not the problem.
Also with P3 it is best to send to Acrobat distiller rather than Writer.
I couldn’t tell from your posting , but I presume you have a pdf writer software installed, if so as someone else said it should appear in all your software [including P3] as just another choice of printer, if not then p3 itself can not create pdf files.
hope this helps.
Bernard Ertl
User offline. Last seen 10 years 29 weeks ago. Offline
Try www.pdf995.com instead of Adobe’s printer driver.
Bernard Ertl
eTaskMaker Project Planning Software
Steven Oliver
User offline. Last seen 12 years 32 weeks ago. Offline
Sounds more like a pdf problem that P3.
Wheb you do a P3 print preview and select the print icon, are you able to select adobe pdf from the list of available printers ?
We are using P3 ver 3.1, is this the latest version of P3? yes, i tried the command print on adobe pdf printer, but it says printer error, so it wont proceed to convert P3 file to pdf file. what shall i do then?
Steven Oliver
You will need a pdf writer, this then acts in the same way as a normal printer except instead of printing a paper copy, it creates a electronic file.
There are a number of free writers available to download from the internet.
HTH
