Highligt Activities in P3.1
Adekunle Arisilejoye
User offline. Last seen 5 years 32 weeks ago. Offline
Hello gys, is there a way around highlighting activites in p3.1
Kunle
Erik,
But what I really want is to highlight the text box not thr bars.
Bobo kay
Erik Jonker
User offline. Last seen 5 years 27 weeks ago. Offline
On the filter menu, you can select the option of highlighting the activities selected.
Unfortunately there are no ways that you can change the format of the description text. You have a column indicating the acitvities you want to highlight. You can also use the pattern function on the bar menu to change the format of bars with coding values.
Erik
Daniel Limson
User offline. Last seen 5 years 15 weeks ago. Offline
Hi Babo,
There is an icon called "progress spotlight" (it looks like a flashlight) once you press that icon, you can basically drag and drop it from the data date to anywhere you like it, for example, you want to highlight all the activities coming for the next two weeks, just drag that spot light 2 weeks from the data date and presto! all the activities within the next two weeks will be highlighted.
Daniel
