Updated prgram as baseline program
vinod raturi
User offline. Last seen 7 years 16 weeks ago. Offline
Hi all ,
Can a updated schedule be stored as a baseline program for further use.
The scenario being that part of out scope has changed after almost 2 yrs , and now the client wants latest updated status to be used as a baseline program .
I tried saving the program as a target program but was unable to do it.
would be helpful , if someone could direct a way out for this.
Shah. HB
Hi vinod
You can treat the updated schedule as target.Make sure the existing pro-gramme[Which you use for monitoring ] and target should not have same file name.Make sure your target and existing pro-gramme are in one folder
User offline. Last seen 1 day 3 hours ago. Offline
Hi Vinod,
Open the project that you wanted to save as target.
Select Tools->Project Utilities->Copy. Once copied, Select Tools->Project Utilities->Target, select the project copied.
Note: Only 2 projects can be display at the same time. If already have 2, replace any one of them.
