resource loading for late S curve
Caner Odabasi
User offline. Last seen 12 years 28 weeks ago. Offline
Hi All
I want to make resource loading for manhours due to late S curve, but when I select late dates in selection criteria for tabular reports resource loading, I get loading for early dates again.
Is anyone have a solution for this problem?
Shah. HB
User offline. Last seen 31 weeks 4 days ago. Offline
You are welcome .I trust you got it
Caner Odabasi
Tnx much Shadul
Shah. HB
Hi caner
In tabular reports select resource option in that choose tabular,select the resource you want to generate s curve early or late,In the time scale tab select late and provide none for early and target options.save it as you wish then run it. It will create a dbf file use the data generated to produce scurve
