ODBC Driver for P3.1
8 replies [Last post]
Ernani Garena
User offline. Last seen 12 years 48 weeks ago. Offline
I have read a part of Mr. Paul Harris Book where he mentioned that P3 can be linked to excel or access but needs ODBC Driver. When I have searched the Internet, there are a lot of ODBC drivers. Please somebody inform me what type of ODBC driver I need to install for me to link P3 to excel or access. Thank you very much!
Gardson Duco
User offline. Last seen 9 years 4 weeks ago. Offline
guys, is there any ODBC drivers for P3.1 if my system is vista?
User offline. Last seen 2 weeks 4 days ago. Offline
I will move to your thread on P3 won’t run, your issue/(our as I had the same problems) on P3 WON’T WORK is RELEVANT TO ANY IN NEED TO INSTALL OBDC DRIVERS, they should be aware of the possible traps.
A D
User offline. Last seen 4 years 3 weeks ago. Offline
Yes, u r absolutely right.
Also Rafael, those drivers are for Windows NT / 2000 only and not for Xp or for Vista.
If u install them on higher version, then it creates problem to your database.
Please check the version of the pervasive ODBC drivers before installation.
Plz advise.
Before installing new software always remember to backup your Data and System Files and/or a Full Backup. At minimum a registry backup.
Database setup is very tricky, avoid messing with them unless you backup and know what the software is doing to your system. This is the main reason I am against P6 as a solution for those not in need of entreprise Stuff.
Ian Rogelio Taño
User offline. Last seen 14 years 43 weeks ago. Offline
Thank you very much! I have uploaded the files.
Ernani
For an article on how to Link P3 Database with Excel or Access:
     http://www.primavera.com.au/Technical%20Papers/020820%20Link%20P3%20Database%20with%20Excel%20or%20Access.pdf
For a link to download Pervasive OBDC drivers for SureTrak and P3:
     http://www.eh.com.au/pm_software.html
Good luck,
Ernani Garena
Please tell what exactly to download because I have visited the website and get lost. I do not know where to go to download the driver. Thanks!
A D
Thats pervasive ODBC Drivers.
U can download from http://ww1.pervasive.com/
